Re: Sachs 504/1A Engine - Piston Seized
Jay Rivett /
Add some heat into the mix after you drain the pb fluid. You could also just plan on replacing your crank. I am not too familiar with the 505 engines but you should be able to find a new one. If you can find a new crank you could just cut the old one off at the con rod and the will allow you to remove the jug from the rest of the engine. Or even just split the cases and remove the crank without cutting.
Just my first thoughts if the jug is un willing to come loose from the piston. Heat before destroying though.
  Sachs 504/1A Engine - Piston SeizedTopic by: Sean Wozniak Sean Wozniak 07/24/20 04:05PM
  Re: Sachs 504/1A Engine - Piston SeizedRe: Jay Rivett Jay Rivett 07/24/20 05:06PM
  Re: Sachs 504/1A Engine - Piston SeizedRe: Sean Wozniak Sean Wozniak 07/24/20 06:21PM
  Re: Sachs 504/1A Engine - Piston SeizedRe: k blum k blum 07/25/20 12:06PM
  Re: Sachs 504/1A Engine - Piston SeizedRe: Aaron Blair Aaron Blair 07/25/20 12:53PM
  Re: Sachs 504/1A Engine - Piston SeizedRe: Papa _ Papa _ 07/25/20 01:44PM
  Re: Sachs 504/1A Engine - Piston SeizedRe: Sean Wozniak Sean Wozniak 07/26/20 05:49PM
  Re: Sachs 504/1A Engine - Piston SeizedRe: Mark Kinsler Mark Kinsler 07/27/20 05:25AM
  Re: Sachs 504/1A Engine - Piston SeizedRe: Sean Wozniak Sean Wozniak 07/27/20 11:58AM
  Re: Sachs 504/1A Engine - Piston SeizedRe: k blum k blum 07/28/20 05:33PM
  Re: Sachs 504/1A Engine - Piston SeizedRe: Mark Kinsler Mark Kinsler 07/28/20 07:49PM
  Re: Sachs 504/1A Engine - Piston SeizedRe: Born to be WillD Born to be WillD 07/29/20 01:36PM
  Re: Sachs 504/1A Engine - Piston SeizedRe: pat splat pat splat 07/31/20 03:24AM
  Re: Sachs 504/1A Engine - Piston SeizedRe: Sean Wozniak Sean Wozniak 07/31/20 01:38PM
  Re: Sachs 504/1A Engine - Piston SeizedRe: Born to be WillD Born to be WillD 07/31/20 03:21PM
  Re: Sachs 504/1A Engine - Piston SeizedRe: Mark Kinsler Mark Kinsler 07/31/20 07:22PM
  Re: Sachs 504/1A Engine - Piston SeizedRe: Saabsonettguy . Saabsonettguy . 07/31/20 08:26AM
