19mm PHBG carburetor woes. No fuel. have everything else.
sketch mo /
Anyone have an idea why I am not getting any fuel to the cylinder. I have fuel in the float, all the jets are clear. I tested compression and spark. still no fuel on the plug.
I am going to tear it down and clean it and stuff, but if there are any suggestions let me know. ... oh i guess it might be clogged past the jets.. I just need to clean it I guess but if anyone knows anything else let me know.
94 main 37 idle 60 starter jet in the carb.
70cc a35 parmakit cylinder, with parmakit coil.
I know I have some old reeds in there, that has a little chip in it. going to switch that out with malossi reeds.
Someone has had to have had this problem before. otherwise ill let you know when I get it fixed. or ill end up trading. this is not the right carb anyways, I wish it had the idle screw facing the other way. if anyone has a 19mm carb they want to trade let me know.
Thanks
  19mm PHBG carburetor woes. No fuel. have everything else.Topic by: sketch mo sketch mo 07/24/20 10:05PM
  Re: 19mm PHBG carburetor woes. No fuel. have everything else.Re: Satan 666 Satan 666 07/24/20 10:32PM
  Re: 19mm PHBG carburetor woes. No fuel. have everything else.Re: * wormdirt * * wormdirt * 07/24/20 10:44PM
  Re: 19mm PHBG carburetor woes. No fuel. have everything else.Re: Jay Rivett Jay Rivett 07/24/20 11:19PM
  Re: 19mm PHBG carburetor woes. No fuel. have everything else.Re: Marc Friedman Marc Friedman 07/25/20 10:35AM
  Re: 19mm PHBG carburetor woes. No fuel. have everything else.Re: Jay Rivett Jay Rivett 07/25/20 10:43AM
  Re: 19mm PHBG carburetor woes. No fuel. have everything else.Re: Marc Friedman Marc Friedman 07/25/20 11:08AM
  Re: 19mm PHBG carburetor woes. No fuel. have everything else.Re: pat splat pat splat 07/25/20 07:25PM
  Re: 19mm PHBG carburetor woes. No fuel. have everything else.Re: P D P D 07/25/20 08:01PM
  Re: 19mm PHBG carburetor woes. No fuel. have everything else.Re: kenny s kenny s 07/26/20 07:50PM
  Re: 19mm PHBG carburetor woes. No fuel. have everything else.Re: Tweaker trash Tweaker trash 07/28/20 02:56AM
  Re: 19mm PHBG carburetor woes. No fuel. have everything else.Re: P D P D 07/28/20 08:19AM
  Re: 19mm PHBG carburetor woes. No fuel. have everything else.Re: Pushrod Fifty Pushrod Fifty 07/29/20 02:19PM
  Re: 19mm PHBG carburetor woes. No fuel. have everything else.Re: Justin Broth Justin Broth 08/01/20 04:16PM
  Re: 19mm PHBG carburetor woes. No fuel. have everything else.Re: Marc Friedman Marc Friedman 08/01/20 05:20PM
  Re: 19mm PHBG carburetor woes. No fuel. have everything else.Re: pat splat pat splat 08/02/20 05:04AM
  Re: 19mm PHBG carburetor woes. No fuel. have everything else.Re: P D P D 08/02/20 08:26AM
  Re: 19mm PHBG carburetor woes. No fuel. have everything else.Re: Justin Broth Justin Broth 09/14/20 09:04PM
  Re: 19mm PHBG carburetor woes. No fuel. have everything else.Re: Marc Friedman Marc Friedman 09/14/20 11:45PM
  Re: 19mm PHBG carburetor woes. No fuel. have everything else.Re: sketch mo sketch mo 08/06/20 09:20PM
