Re: 19mm PHBG carburetor woes. No fuel. have everything else.
sketch mo /
Hey thanks for all the suggestions. I got it to do something crazy! so I switched out the reed for a malossi I had. I got an ad carb which wasn't exactly what i thought but I made it work, maybe better. Also I have the 55 starter, 50 idle and 97 main.
I should get a video of this. I choke it whatever.. when I kick it the stator moves counterclockwise right.. well when it does turn on the stator is moving clockwise! ....
do you get whats happening?
after I kick it, when it comes to a stop, it's kicking over backwards once and turning on.. I think
It seems to idle nice when it does come on.
except it causes the pedal to go backwards and catch up, unless i press it in gently.
wheel spins backwards a little, can feel clutch slipping
Maybe I can just flip the leads on the parmakit cdi coil?
or start messing with the stator and timing,
I am using the small connector as the power I think.
pretty wierd tho huh?
I grabbed these cdi 4 pole stator coils off a parts bike and lined them up with the lines i thought. I hate timing. Pics coming soon.
  19mm PHBG carburetor woes. No fuel. have everything else.Topic by: sketch mo sketch mo 07/24/20 10:05PM
  Re: 19mm PHBG carburetor woes. No fuel. have everything else.Re: Satan 666 Satan 666 07/24/20 10:32PM
  Re: 19mm PHBG carburetor woes. No fuel. have everything else.Re: * wormdirt * * wormdirt * 07/24/20 10:44PM
  Re: 19mm PHBG carburetor woes. No fuel. have everything else.Re: Jay Rivett Jay Rivett 07/24/20 11:19PM
  Re: 19mm PHBG carburetor woes. No fuel. have everything else.Re: Marc Friedman Marc Friedman 07/25/20 10:35AM
  Re: 19mm PHBG carburetor woes. No fuel. have everything else.Re: Jay Rivett Jay Rivett 07/25/20 10:43AM
  Re: 19mm PHBG carburetor woes. No fuel. have everything else.Re: Marc Friedman Marc Friedman 07/25/20 11:08AM
  Re: 19mm PHBG carburetor woes. No fuel. have everything else.Re: pat splat pat splat 07/25/20 07:25PM
  Re: 19mm PHBG carburetor woes. No fuel. have everything else.Re: P D P D 07/25/20 08:01PM
  Re: 19mm PHBG carburetor woes. No fuel. have everything else.Re: kenny s kenny s 07/26/20 07:50PM
  Re: 19mm PHBG carburetor woes. No fuel. have everything else.Re: Tweaker trash Tweaker trash 07/28/20 02:56AM
  Re: 19mm PHBG carburetor woes. No fuel. have everything else.Re: P D P D 07/28/20 08:19AM
  Re: 19mm PHBG carburetor woes. No fuel. have everything else.Re: Pushrod Fifty Pushrod Fifty 07/29/20 02:19PM
  Re: 19mm PHBG carburetor woes. No fuel. have everything else.Re: Justin Broth Justin Broth 08/01/20 04:16PM
  Re: 19mm PHBG carburetor woes. No fuel. have everything else.Re: Marc Friedman Marc Friedman 08/01/20 05:20PM
  Re: 19mm PHBG carburetor woes. No fuel. have everything else.Re: pat splat pat splat 08/02/20 05:04AM
  Re: 19mm PHBG carburetor woes. No fuel. have everything else.Re: P D P D 08/02/20 08:26AM
  Re: 19mm PHBG carburetor woes. No fuel. have everything else.Re: Justin Broth Justin Broth 09/14/20 09:04PM
  Re: 19mm PHBG carburetor woes. No fuel. have everything else.Re: Marc Friedman Marc Friedman 09/14/20 11:45PM
  Re: 19mm PHBG carburetor woes. No fuel. have everything else.Re: sketch mo sketch mo 08/06/20 09:20PM
