Re: Help with domino throttle
Jay Rivett /
It slides over the throttle tube. And sits into the slots that are on it. As long as the tube is put onto the rest of the assembly correctly then the spring will function as intended. But as mentioned it is only a return spring so your throttle turns itself off. A safety feature for sure.
