Are the cases fully mated all around? Any trace of trans oil on the plug? Is the vent partially clogged, creating pressure surges in the case? You can do a leak down test to check your crank case seal.
Subject | Written By | Posted |
Puch Maxi E50 1 speed oil leaking from vent holeTopic by: Carsten Palm | Carsten Palm | 07/26/20 08:35AM |
Re: Puch Maxi E50 1 speed oil leaking from vent holeRe: Pushrod Fifty | Pushrod Fifty | 07/29/20 01:10PM |
