Re: Puch Maxi E50 1 speed oil leaking from vent hole
Pushrod Fifty /
Are the cases fully mated all around? Any trace of trans oil on the plug? Is the vent partially clogged, creating pressure surges in the case? You can do a leak down test to check your crank case seal.
