Re: Point gap vs timing
Mark Kinsler /
On this bike the cam pushes a little fiber tab mounted on the same arm upon which the moveable contact of the point set is affixed. Thus if the point gap is set too small the tab (which I've called a 'cam follower because that's what it is) will stay far away from the rotating cam, only making contact when the piston has moved too far toward top dead center. The points will open for a short period (called the 'dwell angle') and then close once again as the lump rotates past.
If the point gap is set too wide, the points won't ever close, which stops the spark altogether.
Since my only feeler gauge has blades that don't fit comfortably through the flywheel holes I shall find a piece of steel clock pivot wire about the correct diameter and use that.
I shall adjust and report. The timing light is a remarkable piece of equipment.
Mark Kinsler
  Point gap vs timingTopic by: Mark Kinsler Mark Kinsler 07/26/20 05:43PM
  Re: Point gap vs timingRe: P D P D 07/26/20 06:15PM
  Re: Point gap vs timingRe: Overpriced Parts Overpriced Parts 07/26/20 09:07PM
  Re: Point gap vs timingRe: Dirty30 Dillon Dirty30 Dillon 07/26/20 09:45PM
  Re: Point gap vs timingRe: Mark Kinsler Mark Kinsler 07/26/20 10:13PM
  Re: Point gap vs timingRe: Den 23 Den 23 07/26/20 07:17PM
  Re: Point gap vs timingRe: Dirty30 Dillon Dirty30 Dillon 07/26/20 08:54PM
  Re: Point gap vs timingRe: Mark Kinsler Mark Kinsler 07/26/20 09:18PM
  Re: Point gap vs timingRe: Den 23 Den 23 07/26/20 11:42PM
  Re: Point gap vs timingRe: Mark Kinsler Mark Kinsler 07/27/20 05:13AM
  Re: Point gap vs timingRe: Den 23 Den 23 07/27/20 10:28AM
  Re: Point gap vs timingRe: Mark Kinsler Mark Kinsler 07/27/20 12:19PM
  Re: Point gap vs timingRe: Richard Eberline Richard Eberline 07/26/20 10:00PM
  Re: Point gap vs timingRe: Mark Kinsler Mark Kinsler 07/27/20 02:31AM
  Re: Point gap vs timingRe: Mark Anderson Mark Anderson 07/27/20 08:52AM
  Re: Point gap vs timingRe: Mark Kinsler Mark Kinsler 07/27/20 12:05PM
  Re: Point gap vs timingRe: Jay Rivett Jay Rivett 07/27/20 09:02AM
  Re: Point gap vs timingRe: P D P D 07/27/20 10:16AM
  Re: Point gap vs timingRe: Mark Anderson Mark Anderson 07/27/20 09:36AM
  Re: Point gap vs timingRe: Mark Kinsler Mark Kinsler 07/27/20 12:09PM
  Re: Point gap vs timingRe: Den 23 Den 23 07/27/20 12:40PM
  Re: Point gap vs timingRe: Pushrod Fifty Pushrod Fifty 07/27/20 10:28AM
  Re: Point gap vs timingRe: P D P D 07/27/20 10:46AM
  Re: Point gap vs timingRe: Jay Rivett Jay Rivett 07/27/20 10:53AM
  Re: Point gap vs timingRe: Mark Kinsler Mark Kinsler 07/27/20 01:29PM
  Re: Point gap vs timingRe: P D P D 07/27/20 03:57PM
  Re: Point gap vs timingRe: Jay Rivett Jay Rivett 07/27/20 07:12PM
  Re: Point gap vs timingRe: Scott Bard Scott Bard 07/28/20 07:25AM
  Re: Point gap vs timingRe: Den 23 Den 23 07/28/20 08:39AM
  Re: Point gap vs timingRe: Mark Kinsler Mark Kinsler 07/28/20 02:08PM
  Re: Point gap vs timingRe: P D P D 07/28/20 08:52AM
  Re: Point gap vs timingRe: Den 23 Den 23 07/28/20 09:12AM
  Re: Point gap vs timingRe: live ɘvil live ɘvil 07/28/20 06:59PM
  Re: Point gap vs timingRe: Mark Kinsler Mark Kinsler 07/28/20 02:15PM
  Re: Point gap vs timingRe: Mark Kinsler Mark Kinsler 07/28/20 02:00PM
  Re: Point gap vs timingRe: Mike Boyd Mike Boyd 07/28/20 02:22PM
  Re: Point gap vs timingRe: Dirty30 Dillon Dirty30 Dillon 07/28/20 02:39PM
  Re: Point gap vs timingRe: Richard Eberline Richard Eberline 07/28/20 07:28PM
  Re: Point gap vs timingRe: live ɘvil live ɘvil 07/28/20 07:38PM
  Re: Point gap vs timingRe: Scott Bard Scott Bard 07/28/20 09:36PM
  Re: Point gap vs timingRe: P D P D 07/28/20 10:05PM
  Re: Point gap vs timingRe: Dirty30 Dillon Dirty30 Dillon 07/28/20 10:07PM
  Re: Point gap vs timingRe: Mark Kinsler Mark Kinsler 07/28/20 10:20PM
  Re: Point gap vs timingRe: Scott Bard Scott Bard 07/28/20 09:40PM
  Re: Point gap vs timingRe: Mark Kinsler Mark Kinsler 07/28/20 09:47PM
  Re: Point gap vs timingRe: Dirty30 Dillon Dirty30 Dillon 07/28/20 09:48PM
  Re: Point gap vs timingRe: Mark Kinsler Mark Kinsler 07/28/20 10:04PM
  Re: Point gap vs timingRe: Scott Bard Scott Bard 07/28/20 09:41PM
