Re: Point gap vs timing
Jay Rivett /
I am still trying to get my head all around timing and you seem to have a far better understanding of all the science behind it which has been an great read. I have a timing light and a timing tool and I feel like I am going to start using the light more for my bikes as the tool does what you mentioned and make it impossible to see and adjust things when you have it set. The light will require lines on my flywheel which gives me the position I am getting spark at. I can then use a degree wheel to find where the points should be opening and mark that as well. That will allow me to rotate the flywheel to get where I need to make the adjustment and then can fire up and test the change with the timing light.
The feeler type tool that I have is good for finding some measurements but I am finding it harder to set an accurate timing with these days.
Is this sounding correct?
Also I seem to be lost on which direction I would move my stator to advance/retard timing. I feel like it is this. Let's say the flywheel rotates in a clockwise direction. I would rotate the stator counter clockwise to advance the timing and clockwise to restart the timing?
  Point gap vs timingTopic by: Mark Kinsler Mark Kinsler 07/26/20 05:43PM
  Re: Point gap vs timingRe: P D P D 07/26/20 06:15PM
  Re: Point gap vs timingRe: Overpriced Parts Overpriced Parts 07/26/20 09:07PM
  Re: Point gap vs timingRe: Dirty30 Dillon Dirty30 Dillon 07/26/20 09:45PM
  Re: Point gap vs timingRe: Mark Kinsler Mark Kinsler 07/26/20 10:13PM
  Re: Point gap vs timingRe: Den 23 Den 23 07/26/20 07:17PM
  Re: Point gap vs timingRe: Dirty30 Dillon Dirty30 Dillon 07/26/20 08:54PM
  Re: Point gap vs timingRe: Mark Kinsler Mark Kinsler 07/26/20 09:18PM
  Re: Point gap vs timingRe: Den 23 Den 23 07/26/20 11:42PM
  Re: Point gap vs timingRe: Mark Kinsler Mark Kinsler 07/27/20 05:13AM
  Re: Point gap vs timingRe: Den 23 Den 23 07/27/20 10:28AM
  Re: Point gap vs timingRe: Mark Kinsler Mark Kinsler 07/27/20 12:19PM
  Re: Point gap vs timingRe: Richard Eberline Richard Eberline 07/26/20 10:00PM
  Re: Point gap vs timingRe: Mark Kinsler Mark Kinsler 07/27/20 02:31AM
  Re: Point gap vs timingRe: Mark Anderson Mark Anderson 07/27/20 08:52AM
  Re: Point gap vs timingRe: Mark Kinsler Mark Kinsler 07/27/20 12:05PM
  Re: Point gap vs timingRe: Jay Rivett Jay Rivett 07/27/20 09:02AM
  Re: Point gap vs timingRe: P D P D 07/27/20 10:16AM
  Re: Point gap vs timingRe: Mark Anderson Mark Anderson 07/27/20 09:36AM
  Re: Point gap vs timingRe: Mark Kinsler Mark Kinsler 07/27/20 12:09PM
  Re: Point gap vs timingRe: Den 23 Den 23 07/27/20 12:40PM
  Re: Point gap vs timingRe: Pushrod Fifty Pushrod Fifty 07/27/20 10:28AM
  Re: Point gap vs timingRe: P D P D 07/27/20 10:46AM
  Re: Point gap vs timingRe: Jay Rivett Jay Rivett 07/27/20 10:53AM
  Re: Point gap vs timingRe: Mark Kinsler Mark Kinsler 07/27/20 01:29PM
  Re: Point gap vs timingRe: P D P D 07/27/20 03:57PM
  Re: Point gap vs timingRe: Jay Rivett Jay Rivett 07/27/20 07:12PM
  Re: Point gap vs timingRe: Scott Bard Scott Bard 07/28/20 07:25AM
  Re: Point gap vs timingRe: Den 23 Den 23 07/28/20 08:39AM
  Re: Point gap vs timingRe: Mark Kinsler Mark Kinsler 07/28/20 02:08PM
  Re: Point gap vs timingRe: P D P D 07/28/20 08:52AM
  Re: Point gap vs timingRe: Den 23 Den 23 07/28/20 09:12AM
  Re: Point gap vs timingRe: live ɘvil live ɘvil 07/28/20 06:59PM
  Re: Point gap vs timingRe: Mark Kinsler Mark Kinsler 07/28/20 02:15PM
  Re: Point gap vs timingRe: Mark Kinsler Mark Kinsler 07/28/20 02:00PM
  Re: Point gap vs timingRe: Mike Boyd Mike Boyd 07/28/20 02:22PM
  Re: Point gap vs timingRe: Dirty30 Dillon Dirty30 Dillon 07/28/20 02:39PM
  Re: Point gap vs timingRe: Richard Eberline Richard Eberline 07/28/20 07:28PM
  Re: Point gap vs timingRe: live ɘvil live ɘvil 07/28/20 07:38PM
  Re: Point gap vs timingRe: Scott Bard Scott Bard 07/28/20 09:36PM
  Re: Point gap vs timingRe: P D P D 07/28/20 10:05PM
  Re: Point gap vs timingRe: Dirty30 Dillon Dirty30 Dillon 07/28/20 10:07PM
  Re: Point gap vs timingRe: Mark Kinsler Mark Kinsler 07/28/20 10:20PM
  Re: Point gap vs timingRe: Scott Bard Scott Bard 07/28/20 09:40PM
  Re: Point gap vs timingRe: Mark Kinsler Mark Kinsler 07/28/20 09:47PM
  Re: Point gap vs timingRe: Dirty30 Dillon Dirty30 Dillon 07/28/20 09:48PM
  Re: Point gap vs timingRe: Mark Kinsler Mark Kinsler 07/28/20 10:04PM
  Re: Point gap vs timingRe: Scott Bard Scott Bard 07/28/20 09:41PM
