Re: '78 Batavus Regency, Laura M56 sounds like a Pterodactyl
Jay Rivett /
What kind of carb is on there. I thought they had some kind of sha on there. There is only an idle mix, but a few different slides that can be used for better mid range. The air/fuel mix is going to come from the ret and then the air flow through your filter. You can restrict or de restrict the airflow in your airbox. And those carbs have a big difference between idle and WOT. Idle will always be too rich if you have the top end jetted correctly. Always get a few plug chops in around the block before taking it out on a longer ride. Grab a 4 pk of plugs as you will want a new plug for each chop.
  '78 Batavus Regency, Laura M56 sounds like a PterodactylTopic by: Mark Anderson Mark Anderson 07/27/20 09:00AM
  Re: '78 Batavus Regency, Laura M56 sounds like a PterodactylRe: Jay Rivett Jay Rivett 07/27/20 09:08AM
  Re: '78 Batavus Regency, Laura M56 sounds like a PterodactylRe: Mark Anderson Mark Anderson 07/27/20 09:20AM
  Re: '78 Batavus Regency, Laura M56 sounds like a PterodactylRe: Mark Anderson Mark Anderson 07/27/20 09:26AM
  Re: '78 Batavus Regency, Laura M56 sounds like a PterodactylRe: Mark Anderson Mark Anderson 07/27/20 09:47AM
  Re: '78 Batavus Regency, Laura M56 sounds like a PterodactylRe: Jay Rivett Jay Rivett 07/27/20 11:07AM
  Re: '78 Batavus Regency, Laura M56 sounds like a PterodactylRe: Mark Anderson Mark Anderson 07/27/20 11:13AM
  Re: '78 Batavus Regency, Laura M56 sounds like a PterodactylRe: Aaron Blair Aaron Blair 07/27/20 11:16AM
  Re: '78 Batavus Regency, Laura M56 sounds like a PterodactylRe: Mark Anderson Mark Anderson 07/27/20 11:30AM
  Re: '78 Batavus Regency, Laura M56 sounds like a PterodactylRe: Aaron Blair Aaron Blair 07/27/20 11:31AM
  Re: '78 Batavus Regency, Laura M56 sounds like a PterodactylRe: Aaron Blair Aaron Blair 07/27/20 11:35AM
  Re: '78 Batavus Regency, Laura M56 sounds like a PterodactylRe: Mark Anderson Mark Anderson 07/27/20 11:36AM
  Re: '78 Batavus Regency, Laura M56 sounds like a PterodactylRe: Aaron Blair Aaron Blair 07/27/20 11:46AM
  Re: '78 Batavus Regency, Laura M56 sounds like a PterodactylRe: Mark Anderson Mark Anderson 07/27/20 11:51AM
  Re: '78 Batavus Regency, Laura M56 sounds like a PterodactylRe: Jay Rivett Jay Rivett 07/27/20 11:56AM
  Re: '78 Batavus Regency, Laura M56 sounds like a PterodactylRe: Mark Anderson Mark Anderson 07/27/20 12:25PM
  Re: '78 Batavus Regency, Laura M56 sounds like a PterodactylRe: Aaron Blair Aaron Blair 07/27/20 12:31PM
  Re: '78 Batavus Regency, Laura M56 sounds like a PterodactylRe: Mark Anderson Mark Anderson 07/27/20 12:38PM
  Re: '78 Batavus Regency, Laura M56 sounds like a PterodactylRe: Jay Rivett Jay Rivett 07/28/20 04:16PM
  Re: '78 Batavus Regency, Laura M56 sounds like a PterodactylRe: Dan Pasanen Dan Pasanen 07/29/20 10:56AM
  Re: '78 Batavus Regency, Laura M56 sounds like a PterodactylRe: Mark Anderson Mark Anderson 07/29/20 12:01PM
  Re: '78 Batavus Regency, Laura M56 sounds like a PterodactylRe: Dan Pasanen Dan Pasanen 07/29/20 02:28PM
  Re: '78 Batavus Regency, Laura M56 sounds like a PterodactylRe: pat splat pat splat 07/29/20 09:40PM
  Re: '78 Batavus Regency, Laura M56 sounds like a PterodactylRe: Chris Squid Chris Squid 07/30/20 09:29PM
  Re: '78 Batavus Regency, Laura M56 sounds like a PterodactylRe: Mark Anderson Mark Anderson 07/31/20 10:36AM
