The jet that came with it is either a 62 or 64. My intake at the head has reeds and a factory spacer which I left intact. The carb side has the correct shim. I pulled the one out that came with the carb. Was a bitch to get out. I did NOT put an O-ring in there. But, I did test with carb cleaner for air leaks. There was no change in RPMs.
