Re: '78 Batavus Regency, Laura M56 sounds like a Pterodactyl
Aaron Blair /
No, put the shim into the carb. The press the o-ring into the shim. It gives a rubber mating surface fully around the circumference of the intake manifold, so the whole round end is sealed to the carb
The shim fill the space around the intake so it can clamp on, the o-ring is smooshed between the intake and carb throut.
Wouldn't worry about it untill you diagnose your problem tho...it could also be a Piston pin clip that flew out and trashed the cylinder.
  '78 Batavus Regency, Laura M56 sounds like a PterodactylTopic by: Mark Anderson Mark Anderson 07/27/20 09:00AM
  Re: '78 Batavus Regency, Laura M56 sounds like a PterodactylRe: Jay Rivett Jay Rivett 07/27/20 09:08AM
  Re: '78 Batavus Regency, Laura M56 sounds like a PterodactylRe: Mark Anderson Mark Anderson 07/27/20 09:20AM
  Re: '78 Batavus Regency, Laura M56 sounds like a PterodactylRe: Mark Anderson Mark Anderson 07/27/20 09:26AM
  Re: '78 Batavus Regency, Laura M56 sounds like a PterodactylRe: Mark Anderson Mark Anderson 07/27/20 09:47AM
  Re: '78 Batavus Regency, Laura M56 sounds like a PterodactylRe: Jay Rivett Jay Rivett 07/27/20 11:07AM
  Re: '78 Batavus Regency, Laura M56 sounds like a PterodactylRe: Mark Anderson Mark Anderson 07/27/20 11:13AM
  Re: '78 Batavus Regency, Laura M56 sounds like a PterodactylRe: Aaron Blair Aaron Blair 07/27/20 11:16AM
  Re: '78 Batavus Regency, Laura M56 sounds like a PterodactylRe: Mark Anderson Mark Anderson 07/27/20 11:30AM
  Re: '78 Batavus Regency, Laura M56 sounds like a PterodactylRe: Aaron Blair Aaron Blair 07/27/20 11:31AM
  Re: '78 Batavus Regency, Laura M56 sounds like a PterodactylRe: Aaron Blair Aaron Blair 07/27/20 11:35AM
  Re: '78 Batavus Regency, Laura M56 sounds like a PterodactylRe: Mark Anderson Mark Anderson 07/27/20 11:36AM
  Re: '78 Batavus Regency, Laura M56 sounds like a PterodactylRe: Aaron Blair Aaron Blair 07/27/20 11:46AM
  Re: '78 Batavus Regency, Laura M56 sounds like a PterodactylRe: Mark Anderson Mark Anderson 07/27/20 11:51AM
  Re: '78 Batavus Regency, Laura M56 sounds like a PterodactylRe: Jay Rivett Jay Rivett 07/27/20 11:56AM
  Re: '78 Batavus Regency, Laura M56 sounds like a PterodactylRe: Mark Anderson Mark Anderson 07/27/20 12:25PM
  Re: '78 Batavus Regency, Laura M56 sounds like a PterodactylRe: Aaron Blair Aaron Blair 07/27/20 12:31PM
  Re: '78 Batavus Regency, Laura M56 sounds like a PterodactylRe: Mark Anderson Mark Anderson 07/27/20 12:38PM
  Re: '78 Batavus Regency, Laura M56 sounds like a PterodactylRe: Jay Rivett Jay Rivett 07/28/20 04:16PM
  Re: '78 Batavus Regency, Laura M56 sounds like a PterodactylRe: Dan Pasanen Dan Pasanen 07/29/20 10:56AM
  Re: '78 Batavus Regency, Laura M56 sounds like a PterodactylRe: Mark Anderson Mark Anderson 07/29/20 12:01PM
  Re: '78 Batavus Regency, Laura M56 sounds like a PterodactylRe: Dan Pasanen Dan Pasanen 07/29/20 02:28PM
  Re: '78 Batavus Regency, Laura M56 sounds like a PterodactylRe: pat splat pat splat 07/29/20 09:40PM
  Re: '78 Batavus Regency, Laura M56 sounds like a PterodactylRe: Chris Squid Chris Squid 07/30/20 09:29PM
  Re: '78 Batavus Regency, Laura M56 sounds like a PterodactylRe: Mark Anderson Mark Anderson 07/31/20 10:36AM
