No on aaron with the oring. If you have tour carb off. The oring goes in to the intake mou ting area first. The shim I never remove from my intake so I never consider it a part of the carb. I consider the shim part of the intake. So basically the oring is sandwiched between the carb body and the plastic shim. The oring will seal off the clamp gap on the carb body.
