Re: '78 Batavus Regency, Laura M56 sounds like a Pterodactyl
Dan Pasanen /
Per the M56 tech tips pdf in the link above: "Hold the engine at a 45 degree angle, filling it with oil to the bottom side of the fill and drain opening. By doing this, the gearbox will be filled with approximately 80 cc's of oil. Use motor oil SAE 50 or gearbox oil SAE 80. After the break-in period of 500 miles, the oil should be drained, refilled with fresh oil, and then should never require another change."
I haven't ever cracked an M56 open yet, but I don't imagine you should have to heat it to do so. Probably need to for removing the old bearings and possibly installing the new ones. Again, haven't taken this motor apart so I can't even visually think of what it looks like inside.
Gears are probably fine. Hard to say for sure though without looking at them.
  '78 Batavus Regency, Laura M56 sounds like a PterodactylTopic by: Mark Anderson Mark Anderson 07/27/20 09:00AM
  Re: '78 Batavus Regency, Laura M56 sounds like a PterodactylRe: Jay Rivett Jay Rivett 07/27/20 09:08AM
  Re: '78 Batavus Regency, Laura M56 sounds like a PterodactylRe: Mark Anderson Mark Anderson 07/27/20 09:20AM
  Re: '78 Batavus Regency, Laura M56 sounds like a PterodactylRe: Mark Anderson Mark Anderson 07/27/20 09:26AM
  Re: '78 Batavus Regency, Laura M56 sounds like a PterodactylRe: Mark Anderson Mark Anderson 07/27/20 09:47AM
  Re: '78 Batavus Regency, Laura M56 sounds like a PterodactylRe: Jay Rivett Jay Rivett 07/27/20 11:07AM
  Re: '78 Batavus Regency, Laura M56 sounds like a PterodactylRe: Mark Anderson Mark Anderson 07/27/20 11:13AM
  Re: '78 Batavus Regency, Laura M56 sounds like a PterodactylRe: Aaron Blair Aaron Blair 07/27/20 11:16AM
  Re: '78 Batavus Regency, Laura M56 sounds like a PterodactylRe: Mark Anderson Mark Anderson 07/27/20 11:30AM
  Re: '78 Batavus Regency, Laura M56 sounds like a PterodactylRe: Aaron Blair Aaron Blair 07/27/20 11:31AM
  Re: '78 Batavus Regency, Laura M56 sounds like a PterodactylRe: Aaron Blair Aaron Blair 07/27/20 11:35AM
  Re: '78 Batavus Regency, Laura M56 sounds like a PterodactylRe: Mark Anderson Mark Anderson 07/27/20 11:36AM
  Re: '78 Batavus Regency, Laura M56 sounds like a PterodactylRe: Aaron Blair Aaron Blair 07/27/20 11:46AM
  Re: '78 Batavus Regency, Laura M56 sounds like a PterodactylRe: Mark Anderson Mark Anderson 07/27/20 11:51AM
  Re: '78 Batavus Regency, Laura M56 sounds like a PterodactylRe: Jay Rivett Jay Rivett 07/27/20 11:56AM
  Re: '78 Batavus Regency, Laura M56 sounds like a PterodactylRe: Mark Anderson Mark Anderson 07/27/20 12:25PM
  Re: '78 Batavus Regency, Laura M56 sounds like a PterodactylRe: Aaron Blair Aaron Blair 07/27/20 12:31PM
  Re: '78 Batavus Regency, Laura M56 sounds like a PterodactylRe: Mark Anderson Mark Anderson 07/27/20 12:38PM
  Re: '78 Batavus Regency, Laura M56 sounds like a PterodactylRe: Jay Rivett Jay Rivett 07/28/20 04:16PM
  Re: '78 Batavus Regency, Laura M56 sounds like a PterodactylRe: Dan Pasanen Dan Pasanen 07/29/20 10:56AM
  Re: '78 Batavus Regency, Laura M56 sounds like a PterodactylRe: Mark Anderson Mark Anderson 07/29/20 12:01PM
  Re: '78 Batavus Regency, Laura M56 sounds like a PterodactylRe: Dan Pasanen Dan Pasanen 07/29/20 02:28PM
  Re: '78 Batavus Regency, Laura M56 sounds like a PterodactylRe: pat splat pat splat 07/29/20 09:40PM
  Re: '78 Batavus Regency, Laura M56 sounds like a PterodactylRe: Chris Squid Chris Squid 07/30/20 09:29PM
  Re: '78 Batavus Regency, Laura M56 sounds like a PterodactylRe: Mark Anderson Mark Anderson 07/31/20 10:36AM
