Re: 1980 Honda Express NC50 ignition problem
Jason Majernik /
I have ordered a new stator and coil from treats. The old stator seemed to have shorts in the ignition (black/white) and white wire that runs to the rectifier (only in the stator harness). I also took off the headlight and found the headlight wiring to be a little wonky as it was a rigged up with an aftermarket headlight in it. The white wire was simply capped. I have fixed all of this with a good lamp from treats as well and corrected that wiring. This moped is costing mean arm and a leg, but I’m obsessed with finding the problem and am in way too deep for this not to work. Any other suggestions? How do I test the kill switch? I’m not great at testing wiring, but I’m learning.
