Re: trouble shoot a Peugeot that won't start
Aaron Blair /
Can't really trust the compression as the rings haven't gotten hot for years, but is is a good idea to check
You can check the cylinder visually by unbolting the cylinder head and looking into the bore. If the sides are smooth and without scoring or smearing your probably fine. But with a bike that old, you may be looking at a tear down to replace the bottom end seals
It's important that you say what carb you installed and what jet is in it....that way we can tell you what jet to run, you want to handle that first so you don't seize it when it does run.
The best option would be to clean the original carb and reinstall it. Or if you did buy a factory replacement style gurtner, put in the jet from the original carb.
These are single jet carbs. (edited)
  trouble shoot a Peugeot that won't startTopic by: Earl Laboissonniere Earl Laboissonniere 07/29/20 07:17AM
  Re: trouble shoot a Peugeot that won't startRe: Sir Clip Sir Clip 07/29/20 07:24AM
  Re: trouble shoot a Peugeot that won't startRe: Earl Laboissonniere Earl Laboissonniere 07/29/20 07:29AM
  Re: trouble shoot a Peugeot that won't startRe: Earl Laboissonniere Earl Laboissonniere 07/29/20 07:36AM
  Re: trouble shoot a Peugeot that won't startRe: Aaron Blair Aaron Blair 07/29/20 07:55AM
  Re: trouble shoot a Peugeot that won't startRe: Earl Laboissonniere Earl Laboissonniere 07/29/20 08:00AM
  Re: trouble shoot a Peugeot that won't startRe: Aaron Blair Aaron Blair 07/29/20 08:09AM
  Re: trouble shoot a Peugeot that won't startRe: Earl Laboissonniere Earl Laboissonniere 07/29/20 08:26AM
  Re: trouble shoot a Peugeot that won't startRe: Aaron Blair Aaron Blair 07/29/20 08:30AM
  Re: trouble shoot a Peugeot that won't startRe: Earl Laboissonniere Earl Laboissonniere 07/29/20 08:37AM
  Re: trouble shoot a Peugeot that won't startRe: Aaron Blair Aaron Blair 07/29/20 08:38AM
  Re: trouble shoot a Peugeot that won't startRe: Earl Laboissonniere Earl Laboissonniere 07/29/20 08:47AM
  Re: trouble shoot a Peugeot that won't startRe: Aaron Blair Aaron Blair 07/29/20 08:58AM
  Re: trouble shoot a Peugeot that won't startRe: Earl Laboissonniere Earl Laboissonniere 07/29/20 09:22AM
  Re: trouble shoot a Peugeot that won't startRe: Joey P Joey P 07/29/20 10:17AM
  Re: trouble shoot a Peugeot that won't startRe: Earl Laboissonniere Earl Laboissonniere 07/29/20 01:01PM
  Re: trouble shoot a Peugeot that won't startRe: Earl Laboissonniere Earl Laboissonniere 07/29/20 12:19PM
  Re: trouble shoot a Peugeot that won't startRe: Jai Dot Jai Dot 07/29/20 03:46PM
  Re: trouble shoot a Peugeot that won't startRe: Joey P Joey P 07/29/20 04:27PM
  Re: trouble shoot a Peugeot that won't startRe: pat splat pat splat 07/29/20 09:31PM
  Re: trouble shoot a Peugeot that won't startRe: Earl Laboissonniere Earl Laboissonniere 07/30/20 08:09AM
  Re: trouble shoot a Peugeot that won't startRe: Aaron Blair Aaron Blair 07/30/20 10:26AM
  Re: trouble shoot a Peugeot that won't startRe: Joey P Joey P 07/30/20 10:31AM
  Re: trouble shoot a Peugeot that won't startRe: pat splat pat splat 07/30/20 03:13PM
  Re: trouble shoot a Peugeot that won't startRe: cheetahchrome . cheetahchrome . 07/31/20 10:33AM
  Re: trouble shoot a Peugeot that won't startRe: Earl Laboissonniere Earl Laboissonniere 08/01/20 06:43PM
