Re: trouble shoot a Peugeot that won't start
Aaron Blair /
Basically none. There are no valves, cams pushrods or anything in the head. Four bolts and it will slide off, it's just a chunk of metal with fins... then you can look. And hopefully just put it back on. Use some kind of penetrating lube, even wd40 so you don't strip the bolts, go gently. But otherwise not a big deal.
There may be a decomp valve, which could be causing a problem as well. But it'll just be connected to the head with a cable. Don't need to remove the cable it'll stay attached just fine.
If your cylinder looks good, but you have low compression. The decomp valve can be at fault. But really don't worry about that now. I'm more concerned about the cylinder bore.
I'm here all the time by the way and although I'm no genius I'll do my best to help. (edited)
  trouble shoot a Peugeot that won't startTopic by: Earl Laboissonniere Earl Laboissonniere 07/29/20 07:17AM
  Re: trouble shoot a Peugeot that won't startRe: Sir Clip Sir Clip 07/29/20 07:24AM
  Re: trouble shoot a Peugeot that won't startRe: Earl Laboissonniere Earl Laboissonniere 07/29/20 07:29AM
  Re: trouble shoot a Peugeot that won't startRe: Earl Laboissonniere Earl Laboissonniere 07/29/20 07:36AM
  Re: trouble shoot a Peugeot that won't startRe: Aaron Blair Aaron Blair 07/29/20 07:55AM
  Re: trouble shoot a Peugeot that won't startRe: Earl Laboissonniere Earl Laboissonniere 07/29/20 08:00AM
  Re: trouble shoot a Peugeot that won't startRe: Aaron Blair Aaron Blair 07/29/20 08:09AM
  Re: trouble shoot a Peugeot that won't startRe: Earl Laboissonniere Earl Laboissonniere 07/29/20 08:26AM
  Re: trouble shoot a Peugeot that won't startRe: Aaron Blair Aaron Blair 07/29/20 08:30AM
  Re: trouble shoot a Peugeot that won't startRe: Earl Laboissonniere Earl Laboissonniere 07/29/20 08:37AM
  Re: trouble shoot a Peugeot that won't startRe: Aaron Blair Aaron Blair 07/29/20 08:38AM
  Re: trouble shoot a Peugeot that won't startRe: Earl Laboissonniere Earl Laboissonniere 07/29/20 08:47AM
  Re: trouble shoot a Peugeot that won't startRe: Aaron Blair Aaron Blair 07/29/20 08:58AM
  Re: trouble shoot a Peugeot that won't startRe: Earl Laboissonniere Earl Laboissonniere 07/29/20 09:22AM
  Re: trouble shoot a Peugeot that won't startRe: Joey P Joey P 07/29/20 10:17AM
  Re: trouble shoot a Peugeot that won't startRe: Earl Laboissonniere Earl Laboissonniere 07/29/20 01:01PM
  Re: trouble shoot a Peugeot that won't startRe: Earl Laboissonniere Earl Laboissonniere 07/29/20 12:19PM
  Re: trouble shoot a Peugeot that won't startRe: Jai Dot Jai Dot 07/29/20 03:46PM
  Re: trouble shoot a Peugeot that won't startRe: Joey P Joey P 07/29/20 04:27PM
  Re: trouble shoot a Peugeot that won't startRe: pat splat pat splat 07/29/20 09:31PM
  Re: trouble shoot a Peugeot that won't startRe: Earl Laboissonniere Earl Laboissonniere 07/30/20 08:09AM
  Re: trouble shoot a Peugeot that won't startRe: Aaron Blair Aaron Blair 07/30/20 10:26AM
  Re: trouble shoot a Peugeot that won't startRe: Joey P Joey P 07/30/20 10:31AM
  Re: trouble shoot a Peugeot that won't startRe: pat splat pat splat 07/30/20 03:13PM
  Re: trouble shoot a Peugeot that won't startRe: cheetahchrome . cheetahchrome . 07/31/20 10:33AM
  Re: trouble shoot a Peugeot that won't startRe: Earl Laboissonniere Earl Laboissonniere 08/01/20 06:43PM
