Re: trouble shoot a Peugeot that won't start
Joey P /
Yeah, based on your issues, I completely agree. At some point, fuel isn't getting into the cylinder. You said that fuel comes out when you pull out the main jet. Let the carb drain completely dry, put the main jet in, attach the fuel line / turn on the fuel, and then remove the main jet. You should have fuel flow out of there fairly quickly.
If not, one of your passages is still clogged.
> Aaron Blair Wrote:
> I'd bet money it's a fuel issues. Those carbs really cause problems. I
> cleaned my stock gurtner over ten times before I got it running. And
> still ended up replacing it with a dellorto Sha 15:15.
> If it ran at all, it's not timing stopping you. Is the choke on? Are you
> running the stock airbox/airfilter?
> Try filling the float bowl manually maybe?
> It just seems like you aren't getting enough fuel. Have you tried
> shooting some premix down the carb?
  trouble shoot a Peugeot that won't startTopic by: Earl Laboissonniere Earl Laboissonniere 07/29/20 07:17AM
  Re: trouble shoot a Peugeot that won't startRe: Sir Clip Sir Clip 07/29/20 07:24AM
  Re: trouble shoot a Peugeot that won't startRe: Earl Laboissonniere Earl Laboissonniere 07/29/20 07:29AM
  Re: trouble shoot a Peugeot that won't startRe: Earl Laboissonniere Earl Laboissonniere 07/29/20 07:36AM
  Re: trouble shoot a Peugeot that won't startRe: Aaron Blair Aaron Blair 07/29/20 07:55AM
  Re: trouble shoot a Peugeot that won't startRe: Earl Laboissonniere Earl Laboissonniere 07/29/20 08:00AM
  Re: trouble shoot a Peugeot that won't startRe: Aaron Blair Aaron Blair 07/29/20 08:09AM
  Re: trouble shoot a Peugeot that won't startRe: Earl Laboissonniere Earl Laboissonniere 07/29/20 08:26AM
  Re: trouble shoot a Peugeot that won't startRe: Aaron Blair Aaron Blair 07/29/20 08:30AM
  Re: trouble shoot a Peugeot that won't startRe: Earl Laboissonniere Earl Laboissonniere 07/29/20 08:37AM
  Re: trouble shoot a Peugeot that won't startRe: Aaron Blair Aaron Blair 07/29/20 08:38AM
  Re: trouble shoot a Peugeot that won't startRe: Earl Laboissonniere Earl Laboissonniere 07/29/20 08:47AM
  Re: trouble shoot a Peugeot that won't startRe: Aaron Blair Aaron Blair 07/29/20 08:58AM
  Re: trouble shoot a Peugeot that won't startRe: Earl Laboissonniere Earl Laboissonniere 07/29/20 09:22AM
  Re: trouble shoot a Peugeot that won't startRe: Joey P Joey P 07/29/20 10:17AM
  Re: trouble shoot a Peugeot that won't startRe: Earl Laboissonniere Earl Laboissonniere 07/29/20 01:01PM
  Re: trouble shoot a Peugeot that won't startRe: Earl Laboissonniere Earl Laboissonniere 07/29/20 12:19PM
  Re: trouble shoot a Peugeot that won't startRe: Jai Dot Jai Dot 07/29/20 03:46PM
  Re: trouble shoot a Peugeot that won't startRe: Joey P Joey P 07/29/20 04:27PM
  Re: trouble shoot a Peugeot that won't startRe: pat splat pat splat 07/29/20 09:31PM
  Re: trouble shoot a Peugeot that won't startRe: Earl Laboissonniere Earl Laboissonniere 07/30/20 08:09AM
  Re: trouble shoot a Peugeot that won't startRe: Aaron Blair Aaron Blair 07/30/20 10:26AM
  Re: trouble shoot a Peugeot that won't startRe: Joey P Joey P 07/30/20 10:31AM
  Re: trouble shoot a Peugeot that won't startRe: pat splat pat splat 07/30/20 03:13PM
  Re: trouble shoot a Peugeot that won't startRe: cheetahchrome . cheetahchrome . 07/31/20 10:33AM
  Re: trouble shoot a Peugeot that won't startRe: Earl Laboissonniere Earl Laboissonniere 08/01/20 06:43PM
