Re: trouble shoot a Peugeot that won't start
cheetahchrome . /
If the bike has done some caughing or poping when trying to start yes it could be that the flywheel timing has slipped. Maybe the PO had the flywheel off and it was not cranked down tight enough.
You can check a rough estimate of the timing by just removing the spark plug and then use a small screwdriver to feel for the top of the piston. When the piston is at the very top of the stroke then glance at the rubber grommet that holds the spark plug cable and you will see the arrow line will be about 3/4 if an inch to the right of the center of the rubber grommet.
If its like roughly in that area give or take a 1/4" it will start. If it's 2-3" on either side your timing has slipped
(edited)
  trouble shoot a Peugeot that won't startTopic by: Earl Laboissonniere Earl Laboissonniere 07/29/20 07:17AM
  Re: trouble shoot a Peugeot that won't startRe: Sir Clip Sir Clip 07/29/20 07:24AM
  Re: trouble shoot a Peugeot that won't startRe: Earl Laboissonniere Earl Laboissonniere 07/29/20 07:29AM
  Re: trouble shoot a Peugeot that won't startRe: Earl Laboissonniere Earl Laboissonniere 07/29/20 07:36AM
  Re: trouble shoot a Peugeot that won't startRe: Aaron Blair Aaron Blair 07/29/20 07:55AM
  Re: trouble shoot a Peugeot that won't startRe: Earl Laboissonniere Earl Laboissonniere 07/29/20 08:00AM
  Re: trouble shoot a Peugeot that won't startRe: Aaron Blair Aaron Blair 07/29/20 08:09AM
  Re: trouble shoot a Peugeot that won't startRe: Earl Laboissonniere Earl Laboissonniere 07/29/20 08:26AM
  Re: trouble shoot a Peugeot that won't startRe: Aaron Blair Aaron Blair 07/29/20 08:30AM
  Re: trouble shoot a Peugeot that won't startRe: Earl Laboissonniere Earl Laboissonniere 07/29/20 08:37AM
  Re: trouble shoot a Peugeot that won't startRe: Aaron Blair Aaron Blair 07/29/20 08:38AM
  Re: trouble shoot a Peugeot that won't startRe: Earl Laboissonniere Earl Laboissonniere 07/29/20 08:47AM
  Re: trouble shoot a Peugeot that won't startRe: Aaron Blair Aaron Blair 07/29/20 08:58AM
  Re: trouble shoot a Peugeot that won't startRe: Earl Laboissonniere Earl Laboissonniere 07/29/20 09:22AM
  Re: trouble shoot a Peugeot that won't startRe: Joey P Joey P 07/29/20 10:17AM
  Re: trouble shoot a Peugeot that won't startRe: Earl Laboissonniere Earl Laboissonniere 07/29/20 01:01PM
  Re: trouble shoot a Peugeot that won't startRe: Earl Laboissonniere Earl Laboissonniere 07/29/20 12:19PM
  Re: trouble shoot a Peugeot that won't startRe: Jai Dot Jai Dot 07/29/20 03:46PM
  Re: trouble shoot a Peugeot that won't startRe: Joey P Joey P 07/29/20 04:27PM
  Re: trouble shoot a Peugeot that won't startRe: pat splat pat splat 07/29/20 09:31PM
  Re: trouble shoot a Peugeot that won't startRe: Earl Laboissonniere Earl Laboissonniere 07/30/20 08:09AM
  Re: trouble shoot a Peugeot that won't startRe: Aaron Blair Aaron Blair 07/30/20 10:26AM
  Re: trouble shoot a Peugeot that won't startRe: Joey P Joey P 07/30/20 10:31AM
  Re: trouble shoot a Peugeot that won't startRe: pat splat pat splat 07/30/20 03:13PM
  Re: trouble shoot a Peugeot that won't startRe: cheetahchrome . cheetahchrome . 07/31/20 10:33AM
  Re: trouble shoot a Peugeot that won't startRe: Earl Laboissonniere Earl Laboissonniere 08/01/20 06:43PM
