Re: QT50 Water in crank case
Den 23 /
Here's what I would do. I would pour maybe 1 pint of denatured alcohol in the case. The alcohol will absorb the water. Then remove the exhaust pipe and the spark plug. Then kick it over until you think that everything has been pumped out.
