Re: QT50 Water in crank case
Den 23 /
> Den 23 Wrote:
> Here's what I would do. I would pour maybe 1 pint of denatured alcohol
> in the case. The alcohol will absorb the water. Then remove the exhaust
> pipe and the spark plug. Then kick it over until you think that
> everything has been pumped out.
I forgot to mention that after kicking it over to pump out all of the alcohol let it sit for a couple of hours. This will give the remaining alcohol time to evaporate taking the absorbed water with it.
