Re: 2008 Tomos A55 Clutch....is it adjustable?
Dirty30 Dillon /
If you didn't check/change oil before riding that's a large possibility. Also, if it was neglected it could be that your friction material is gone. Either way, pulling the cover is the best way to diagnose any clutch issues.
There are no manual adjustments you can make to reduce slip, as it's actuation is based on centrifugal force and friction.
