I know that you can replace the spring in the 2nd speed clutch on the a35, but I'm not positive on the a55. Probably the same though. Treats has some springs at different stiffness you can try. The stock is going to engage the earliest and the stiffer the spring the later(higher rpm) it will grab and shift. Stock bikes may not be able to get the stiffest spring to engage fully.
