I think you have to at least cut the wire to the old condenser when you replace it. When removing the flywheel remember the nut is reverse threaded. If the coil is bad will be chalky looking and perhaps show some cracks. Check that your ground strap is secure. Very cool rear rack, but what in the world is going on with that seat? You must be really tall! :) (edited)
Re: '78 Moby V50, stall issue.
Subject | Written By | Posted |
'78 Moby V50, stall issue.Topic by: Greg Bowl | Greg Bowl | 07/30/20 01:17PM |
Re: '78 Moby V50, stall issue.Re: Stephen Keller | Stephen Keller | 07/30/20 02:02PM |
Re: '78 Moby V50, stall issue.Re: Greg Bowl | Greg Bowl | 07/30/20 03:27PM |
Re: '78 Moby V50, stall issue.Re: P D | P D | 07/30/20 03:38PM |
Re: '78 Moby V50, stall issue.Re: Mike Boyd | Mike Boyd | 07/30/20 02:40PM |
Re: '78 Moby V50, stall issue.Re: P D | P D | 07/30/20 02:50PM |
Re: '78 Moby V50, stall issue.Re: Greg Bowl | Greg Bowl | 07/30/20 03:32PM |
Re: '78 Moby V50, stall issue.Re: Pushrod Fifty | Pushrod Fifty | 07/30/20 08:46PM |
Re: '78 Moby V50, stall issue.Re: Greg Bowl | Greg Bowl | 07/31/20 07:00AM |
Re: '78 Moby V50, stall issue.Re: P D | P D | 07/31/20 09:40AM |
