Re: Tomos a35 not idling, clutch problem?
Hepatitis J [OFMC] /
I think pat is right and you're just very rich. 104 is a big ass jet and it looks like youve got the choke on.
Does the bike just sputter and die when you hit the brake or does it lock up and die?
I have very similarly set up a35 and am running an 86 main with the stock 45 idle jet and a lean ass w11 needle I think.
That's just a reference point, you'll have to dial that carb in yourself.
I would maybe hold off on opening up the transmission side for a bit. If you do decide to open it up, pay attention to where the shims are.
  Tomos a35 not idling, clutch problem?Topic by: James Boehnlein James Boehnlein 07/30/20 11:39PM
  Re: Tomos a35 not idling, clutch problem?Re: pat splat pat splat 07/31/20 03:14AM
  Re: Tomos a35 not idling, clutch problem?Re: James Boehnlein James Boehnlein 07/31/20 09:27AM
  Re: Tomos a35 not idling, clutch problem?Re: James Boehnlein James Boehnlein 07/31/20 09:30AM
  Re: Tomos a35 not idling, clutch problem?Re: James Boehnlein James Boehnlein 07/31/20 09:31AM
  Re: Tomos a35 not idling, clutch problem?Re: Mark alan Mark alan 07/31/20 10:52PM
  Re: Tomos a35 not idling, clutch problem?Re: Mark alan Mark alan 07/31/20 10:55PM
  Re: Tomos a35 not idling, clutch problem?Re: Mark alan Mark alan 07/31/20 10:59PM
  Re: Tomos a35 not idling, clutch problem?Re: Hepatitis J [OFMC] Hepatitis J [OFMC] 08/01/20 12:56AM
  Re: Tomos a35 not idling, clutch problem?Re: James Boehnlein James Boehnlein 08/01/20 01:15AM
  Re: Tomos a35 not idling, clutch problem?Re: Hepatitis J [OFMC] Hepatitis J [OFMC] 08/01/20 11:48AM
  Re: Tomos a35 not idling, clutch problem?Re: James Boehnlein James Boehnlein 08/01/20 01:17AM
  Re: Tomos a35 not idling, clutch problem?Re: James Boehnlein James Boehnlein 08/01/20 11:57AM
  Re: Tomos a35 not idling, clutch problem?Re: pat splat pat splat 08/02/20 05:29AM
  Re: Tomos a35 not idling, clutch problem?Re: Mark alan Mark alan 08/02/20 10:51AM
  Re: Tomos a35 not idling, clutch problem?Re: James Boehnlein James Boehnlein 08/02/20 01:26PM
