Folks, headlight was working but dim, tried horn, then all voltage output
is nil, suspect something under flywheel is at fault, after I remove flywheel
what do I check? what makes the 6 volt dc current? 1st time working on these little bikes, wish it was a plane or car then I would be alrite. thanks Mike.
Bike still does run ok, just no 6 volt output
