Large spring clip on starter plate
Bill Donati /
So now I have put in a new crank, seals and bearings but when putting the clutch back together after I torqued the clutch in at 20 lbs. and put on the starter plate it doesn't go on far enough to get the big spring clip into the grove. It is just a Millimeter from snapping into the grove but the plate won't go in far enough for the ring to seat. SO NOW WHAT.
