The screws for the intake will not budge, what’s up here?!? I’m becoming frustrated quick
QT50, why can’t I get the screws out of the intake??!
Re: QT50, why can’t I get the screws out of the intake??!
You sir, are correct. I am indeed not using one of those.
Is this something I am going to be investing I. If I want those screws out?
> P D Wrote:
> I'll bet you're not using one of these :
> https://www.northerntool.com/images/product/400x400/158/15825_400x400.jpg
Unfortunately, yes. And sometimes not even an impact driver by itself can help.
Using a compatible JIS bit will help.
When you put it back together get a set of metric Allen bolts. They are available on eeebay as a complete custom set for QT engines, not very expensive and look really nice when it's all back together.
Well I didn’t make it to northern tool instead I mildly adjusted my vise grips/channel locks, whatever you want to call them.... I clamped down and turned them dudes straight out til they cracked, then a screw driver did the job fine.
And toward the other commenter, yes when this whole things over a proved to run well it’ll get nice new screws and bolts.
Photo is my semi finished product
