Honda C102 Starting Motor
The starting motor on my C102 doesn’t work and Im having trouble removing the cap on back of the motor . I’ve removed the 2 screws but can not get the cap off . Thanks
Re: Honda C102 Starting Motor
Post a pic of what you're working on .
I finally got the end cap off the starter motor however in the process I mangled the large harness with the 4 “0” shaped pieces that go around the armature and held on by 4 Phillips head screws on the outside of the case . The armature tested perfect but that part I screwed up is probably impossible to find or repair. Thanks (edited)
I finally got the end cap off the start or motor however in the process I mangled the large harness with the 4 “0” shaped pieces that go around the armature and held on by 4 Phillips head screws on the outside of the case . The armature tested perfect but that part I screwed up is probably impossible to find or repair. Thanks
Pushrod Fifty /
Built to last, so the book says.
