tiny screws in Vespa Bravo headlight switch
Carl Johnson /
Hello. I recently got a '77 Vespa Bravo. I've been fixing things slowly on it and my next thing is the lights. The switch is bad, but the problem is simple: the wires aren't connected properly since 2 out of 3 of the tiny screws that hold the wires are missing.
As far as I can tell this is maybe an M2 or M2.5 screw that's about 3mm long. Where the heck can I get a screw this small? I don't think hardware stores go that small and I'm trying to avoid huge "computer, phone, glasses" type assortments on the interwebs.
I could always just solder them I guess but I like how easily disconnect-able it is with the screws. I can send a picture of the one screw I have and stuff if that helps, but I found this picture also which shows the switch and the screws sticking out of the posts:
https://myronsmopeds.com/wp-content/uploads/2012/09/CEV-turn-signal-switch-substitute.jpg
Re: tiny screws in Vespa Bravo headlight switch
Check Ace Hardware . Take a switch along .
1934 E Avenida De Los Arboles, Thousand Oaks, CA 91362
You might be pleasantly surprised .
Carl Johnson /
I meant to say that Lowes and Home Depot don't seem to carry screws that small, but if Ace is the place, I will go a bit farther and give it a shot!
Ace is a bit higher priced , but , they usually have what I need , without having to buy a lifetime supply . ;) (edited)
just solder it u can always unsolder.
Carl Johnson /
I found a replacement switch in the meantime for a clean, stock look.
That'll work . ;)
Mc Master Carr would have it bet
Finally someone has come up with Vespa spare parts...maybe you need to set up a web based business for your marvelous new products. More to come soon I hope..
