Gas tank pinhole leak fix
jamin townsley /
Was stoked about this project until I started soaking the tank in evaporust and found a pinhole leak at the bottom of the tank. Any best practices for repair? Or should I just throw all this hardware on a pinto frame that I have?
Re: Gas tank pinhole leak fix
Tweaker trash /
Pinto frame!
Use Caswell tank sealer, it's the only good one. I kreem'd a tank cause I got the kreem for free and the pinhole was fixed for all of 2 weeks. It took me a week to prep the goddamn tank
jamin townsley /
Thanks y’all!
jamin townsley /
A pinto za50 would be nasty!!!
id braze it. then some paint.
Moped Lar (OFMC) /
I’d poke around the area of the pin hole with a nail. You might find that It is worse than just one pin hole. It usually is.
Jack Rutherford /
Yep, tip of the iceberg, tip of the iceberg.
Jason Majernik /
I had one of these on an old beat up tank. I added JB weld to it. It worked, but was ugly. No uglier that the original. I drained the tank first.
