If it were mine , I'd simply sand any high spots down on both the piston and cylinder .
Clean the ring landing .
Yes , you can run with just the top ring , no problem .
Definitely use good gaskets . I'd even use a spray sealer on the base gasket .
Sure it makes for harder clean up , but , it also helps seal any air leaks .
