Re: Soft seized - Am I fucked?
Cpt. F. /
Hey Matt, remove the one good ring, sand all the seized spots on piston and cylinder with a high grit, put good ring on and run. It'll be fine.
Obviously make sure your gaskets are good a give it a spray down test to verify no leaks.
