> Born to be WillD Wrote:
> easy, just drill a big hole in a lil 1 inch piece of steel to bolt onto
> that motor mount and drill a hole thru for a barrel adjuster to receive
> the cable housing and you're gtg
That may be what was used originally from the factory on earlier models. From the looks of that Garelli it looks to be 1977 or older. Everything ive owned and worked on has been 1978 and up.
