Kinetic TFR Start Issue
Larry Humpolick /
Hello
Back at this again this moped still has the same issue that it wont run more then a few sec ih have taken this apart . i clean the carb lost count after i,am about to junk the dam thing i did the bbk ,check for any leaks, reseal every thing i see 2 screws on the right side What are the adjustments? Should i replace the float spring loaded pin ? I could not mount the air filter on this unit . my gut tells me to writer off the 400.00 I don,t want to dump any more money in this I will give up riding 2 wheels . Because of health this was my lase chance to get out. thank you in advance for help on this.
Larry
