1979 Motobecane carburetor replacement
Brian Stephens /
I just put in 15.15 AV7 SHA carburetor In my 1979 Moby. Probably a silly
question but it is reviving. Loosened the throttle cable a bit. Was wondering could the choke cable also be to tight? Maybe throttle cable stilL to tight? Thank you for any advice.
Bks
Re: 1979 Motobecane carburetor replacement
Brian Stephens /
Got it throttle slide was not closing all the way!
Good you have it sussed . ;)
Brian Stephens /
Was wondering about the main jets? I started with a 58 ran great changed it to a 60 ran the same? Is it supposed to change much between jet sizes?
> sizes?
You really need to tune it. You risk running too lean and seizing your motor. Here's some info: https://www.mopedarmy.com/wiki/Plug_chop
Brian Stephens /
Great thanks I will.
For a completely stock AV7 you should have 58-62 jet, depending on the original configuration of the engine and if you have changed out the restrictive stock intake for a 15mm intake.
