Clutch or piston?
Francisco Rodriguez /
Hello I recently upgraded my za50 puck 2 big bore kit with a new carburetor as I was writing it it felt like the clutch seized up on me I tried to peddle and pull the clutch to start it and as I pull the clutch the pedal stop moving. I can't get it started. Any idea on what it is ? I hope it's at the piston.... Thanks guys
Re: Clutch or piston?
Dirty30 Dillon /
Congratulations, you seized your bike
Overpriced Parts /
Yup hi unchecked timing, incorrect jetting, not prepped kit, possible air leaks and or too low of gearing and not protected by a temperature gauge = heat = seize
Hepatitis J [OFMC] /
Hell yeah
Sorry Francisco, I agree with the others. Get the cylinder pulled off and see if it can be saved. Probably not tho. I advise grabbing the TCCD kit from treatland.tv or the DMP kit from dos cycles. Both are inexpensive kits and easy to learn and work with.
wait, as you were writing this happened? was it even running after mods?
