Sachs 505 gears welded question
Has anyone had your gears slip from the shaft and had to weld it.
This is my next project
Re: Sachs 505 gears welded question
Are the gears pressed on with a friction fit? If so, that's what green loctite is for.
No loctite. Welded will be much stronger
Yeah welding is a lot stronger. But it is set up that the gears can be replaced separate from other parts. If you weld them on to the shaft and you break off some teeth at some point, then you have to replace a lot more.
Dont reengineer the bike, fix it how it was designed to run.
I want welded gears.
If I have to replace so be it....its not meant to run an 80cc reed athena w hpi either.
