Honda Express NC50 parts source
Does anyone have good source for parts? I mean things like a carb rebuild kit, come clamps, fuel and oil lines.
Re: Honda Express NC50 parts source
treatland for sure
maybe also doscycles, lucky2strokes and dennycycles
Fuel and oil lines, fuel filters, spark plugs, hardware, can all be found at treatland.tv or you can usually find that stuff locally sourced at a motorcycle or honda shop.
Engine gaskets and carb rebuild kits are also on treatland right now, and they just added a few different NC50 party kits if you want to go big. New exhausts, cylinder kits, and carburetor upgrades.
I doubt you need any kind of carb kit . Just be sure to clean every passage as clean as new entry to exit .
As for the other items you list , any decent hardware store should have what you need .
If the oil lines are in tack , just continue using them .
BikeBandit.com used to have some stuff for them, not been on in a while. All above mentioned shops are great sources.
