Vespa Ciao center cover
Does anyone happen to know the bolt/screw size for the Ciao engine cover? I found the Vespa part# 102986, but cant find actually specs. I guess my Google game is weak so I came here to ask for help. Also, if anyone knows cross over numbers for stock belt replacement that would be amazing. I believe I crossed it to a Gates 960, but not sure.
Re: Vespa Ciao center cover
all the bolts n nuts for that center cover and bracket are m6 x1, the two shorts that go to the sub frame r shorter and the top center one right in the middle is fatter with a big mushroom head.
look on myrons for belt size, always liked that lever that allows u to tension belt by moving the motor easily.
