Honda Hobbit STILL no compression
Jessie Paull /
I'm freaking stumped. Months ago I over torqued my cylinder and snapped a bolt off in the case, which kicked off a series of events that resulted in my bike having no compression and having done the following:
- New stock piston with pre-installed rings
- Rehoned stock cylinder
- New head and base gaskets
- Cylinder studs to replace the bolts
Could it be the cylinder head or something?
Re: Honda Hobbit STILL no compression
Jessie Paull /
I've also sprayed soapy water around the case and cylinder and don't see any bubbles when I'm pedaling. Thing just doesn't want to start..
Have you checked the decomp? The valve is literally there to give no compression so that could be a problem if it's stuck open or something. So when you pedal it it's got no resistance, the flywheel spins and the motor puts along but it's just got nothin?
Jessie Paull /
Basically yes, but it does have a *little* resistance, just not very much. When I pulled the do compression it has even less resistance (as expected) so it seems like it's closing. Maybe it's not making a good enough seal?
I pulled the head off again and it's a little dirty I guess, but I can't tell if there's anything really wrong with it
Jessie Paull /
I'm only getting about 25 PSI with a tester
Being as you have the head off , pull the valve and lap it in .
Then there's that question answered .
Yeah lapping the valve is the best way. Buy some lapping compound, Google how to lap valves and bam you've got it
Jessie Paull /
I'll go out and get some lapping compound tomorrow and try that, thanks.
In the meantime I took some WD40 and a wire brush to it and cleaned up most of the carbon
Much better^ . ;)
judging by the amount of carbon on the head , there's a good chance the rings are carboned in place and unable to move . That might account for or at least add to the possibility of low compression . (edited)
Jessie Paull /
Still no luck after cleaning up the cylinder head and lapping the decomp valve - compression still around 25 PSI and won't start
The piston and rings are brand new. Any other ideas? Could the rings not be seating, could I have not honed the cylinder bore enough?
What is the ring end gap ?
u might try lapping your head and cylinder top to ensure its flat, and you are using a new head gasket yeah? looks like freash gas is all around head.
Okay, so what's your cylinder look like? Are your rings gapped and installed correctly?
Jessie Paull /
Appreciate the responses - just pulled the head and cylinder back off to check things out some more
What looks like fresh gas is just two stroke from when I lubed all the gaskets during initial installation. The head gasket *was* new; do I need to replace it again when I put everything back together again?
This piston had the rings pre-installed from Treats, but I took them out to measure the gaps and got .02mm for the top ring and .016 mm for the bottom ring.
The ring gaps seem close enough .
What is the piston to cylinder clearance ?
That should be measured a couple different places through the cylinder .
Jessie Paull /
Sorry I'm not exactly sure how to measure that - is that the difference between the diameters of the cylinder bore and piston?
> Jessie Paull Wrote:
> that's the difference between the diameters of the cylinder bore and piston?
Yes . Unless you have an inside caliper , like below , measure top and bottom of the bore and the piston in a couple places from the landings to the skirt bottom .
I realize now you said you rehoned the stock cylinder. I'd bet money you took too much off and wound up overboring the cylinder, that's basically the only thing left that could cause the no compression
Jessie Paull /
> P D Wrote:
> piston?
Gotcha - I'll have to pickup some calipers and check it out. Thanks
As much as this would suck I almost hope this is the case just so I can know what the damn issue is. I've been tempted to throw in the towel and pull the trigger on a DR kit, but I'm also worried that I'll get a kit and have the thing still not start on me -_- just really wanted to get it working stock again first
That is a good way to go .
U can see where its leaking along the decomp passage, take that cylinder to a FLAT surface with some sandpaper ROUGH 150 to start, finish with 600, you'll see that is low along the decomp edge with the black gum.
Do the same with the head. Please do not hit the darn aluminum head with a wire wheel, all u doing is loosing compression with all those scratches. Sand those all out on a Flat surface, cleaning the surface periodically with some compressed air, I use a small granite chunk.
Jessie Paull /
So just trying to make sure I understand correctly - you're saying this is indicative of a leak along the decompression passage:
And that likely the cause is that the surface is lower in this area, so the goal is to sand the cylinder and head down so both surfaces are completely flat and level?
I'm with Nick on this one, makes the most sense. Can somebody send this man a stock cylinder?
Emil Kniemel /
> Mike Boyd Wrote:
> you
> basically
This was my guess as well. But I say go for the DR and don't look back.
Pull the studs and put the bolts back in. Some studs don’t have enough thread to torque. Some studs also bottom out in case and don’t torque down correctly
Easy try before you sand.
along that whole edge, youll see after a couple of passes, cylinder being steel is much more forgiving than the aluminum head, get all the scratches out. reusing old gasket is fine.
Updates?
Did you check the valve timing? Also the valve/tappet clearance.never worked on the hobbit but rebuilt a few pushrod C100 Cub engines . Put your finger or thumb over the spark plug hole and see if you have any compression. This should be an easy problem to diagnose . I bought a non running engine off EBay . The kickstart shaft was broke but I just finished replacing the broken one on my 1965 Cub . The timing gears were off 180 degrees .the piston was upside down as were the rings. It also had the wrong piston as it stood 1/8 inch over the cylinder.Then on another engine they had the valves cranked down so much they weren’t closing on the compression stroke.
No valves on a Hobbit.....
Hobbits a 2 stroke lol, totally different powertrain than the pushrod Honda's
