75 maxi lights stopped working?
The other day I was heading for a ride and noticed my headlight didn’t turn on - I slapped the headlight and it turned on - was fine the whole ride. Next day went to start it and no lights head, tail, or speedo. Horn still works. Checked the wiring and made sure everything was connected and it looks good. Any ideas?
Thanks y’all!
Re: 75 maxi lights stopped working?
I mean you slapped it and it came back on, that tells you it's a loose wire somewhere. The fact that half of your shit doesn't work anymore means it's more than likely a bad ground.
Overpriced Parts /
Yeah check the lightbulb the solder on the end is could be melted or corroded
mike houlihan /
What do you mean check the lightbulb? Head, tail, or both? Having similar problem on one of mine
Check all electrical connections and contacts , including all ground points .
They all have to be shiny metal clean and scratch tight .
If you assume they are good , you might just be chasing ghosts .
