Questions about pre 2003 tomos engine.
Yeah folks I have a 2004 tomos a35 engine. I need to know if my stator will interchange/Mount onto a pre 2003 a35 engine??? Thanks in advance.
Re: Questions about pre 2003 tomos engine.
♣Slew Foot♣ /
Points models will have a 4 point mount if they are compatible with the Cdi. The 3 point mounts are not too easy to mod to use Cdi
So in noob terms are you saying 2003 an older a35 is points. So my cdi engine stator can't go on??
♣Slew Foot♣ /
Some had the four point mount even though they were points models. It needs two opposite mounts.
Yeah my 04 has 4 mounts. The pre 03 must have 3
As long as you can mount up your stator to be the same direction then it should work. It may not be a slap on and go deal as the timing may need some fine tuning, but it should work. As long as you get two bolts on opposite sides in it will be fine.
Jay moped junkyard has a35 kitted less than a thousand miles on transmission. 64cc kit fresh never fired. $500.00
