Vespa gearbox question
I am switching gear boxes on my Ciao and I need to swap the pedal engagement switch from the old box to the new one. What is the secret to removing these two pieces? I searched the site and couldn’t find any info. Thanks for any help ✌️
Re: Vespa gearbox question
Dirty30 Dillon /
If I recall, you simply pop/pry off the plastic cap and than pull the engagement fork out the inside.
As for the disengage lever, I have no clue.
What transmission are you swapping in that didn't have those things already?
I am switching from single to variated. I got the pinasco box from treats. They made it sound so easy in the description 😂
Dirty30 Dillon /
Yeah, it's not as easy.
Makes sure you press the roller bearings in correctly or you'll get some bad wear.
Yup yup thanks for the tips. Got the fork out. Now for the lever...I want to pry but I just don’t want to break it
For future reference the pedal disengagement lever presses right out.
