Hard time on hills
1978 batavus m56... struggles on small hills. Where should I start for making repairs and/or adjustments? Thanks
Re: Hard time on hills
Sounds normal.
I don’t think it’s normal, my other moped goes up small hills just fine. I’m talking really non-steep hills. My moped goes from 25 mph to like 1 mph lol. I’m wondering if I need to adjust the idle screw or something.
Idle screw would do nothing for your problem.
It sounds like you may have low compression. Possibly a bad seal, or maybe just an airleak someplace.
Ah ok thanks
Or , it may just be jetted slightly 'wrong' .
Dirty30 Dillon /
I would 100% put it down to two things: worn bore/rings, or clogged exhaust.
I wondered about that. I’ll start by unclogging you my exhaust . Thank you
Overpriced Parts /
What TopSpeed do you get on the straightaways?
generally around 23-25mph
Overpriced Parts /
Is your bike a 25mph model or 30 mph model
ALWAYS go ahead and gap and replace a spark plug. Keep the old one in the tool bag.
But it could be clogged exhaust like said earlier.
Hey Don thanks. I’ve got a new correctly gapped spark plug in there now, it didn’t run at all until I did that. So now I’m just troubleshooting. I’ve got good compression, spark and the carb was all cleaned recently. I think it very well could be exhaust or a jetting issue. I very much appreciate everyone’s ideas!
Dave Thacker /
Compression and if that is good think about adding some teeth to the rear sprocket.
Ok good idea
Adding teeth to your sprocket will make the bike faster on the top speed but will affect your ability to go up hils even more and slow down the take off as well.
> take off as well.
Quote: Dave Thacker /crafted
Sep 15, 2020 08:29PM
;) (edited)
Great info, thank you all!
Are you sure it isn't the 20mph model? Did you check?
Yes, there's a whole crew of people here to help. That's what has always been great about MA.
I don’t know which model it is But it’s got a m56 engine and encarwi h12 carb.
I had the same problem. Took off the exhaust and ran it to see if it was clogged. Nothing. Cleaned the carb. Puch Magnum barely would make it up hills and was slow. Rear tire got wobbly after a long ride and I took it apart. One side was completely missing a bearing on the axle. The axle was grinding through the bearing cup. Now I have to do an upgrade to sealed bearings. Check your front and rear axle bearings.
Ok I will
How are the reeds?
Good question on reeds. I figure this bike will be a fall/winter project. I’ll check our bearings and reeds. I might ask more questions, this is pretty new to me but I’m reading everything on the topic of mopeds. I’m obsessed!
