Air leaks only when motor is warmed up?
Is this a thing? First time I really had this happen to me. At idle and low temps all is fine. Once warmed up, leaks at head, base and intake??
E50 65cc airsal
Thicker gaskets? Gaskets plus gasket maker? Open to suggestions
Thanks
Andrew
Re: Air leaks only when motor is warmed up?
Dirty30 Dillon /
Frankly, it's really unlikely that it runs fine, and then develops simultaneous multiple leaks. I'd guess it's a leak at the intake before anything, if you're running no-filter/airbox, the slightest atomized carb cleaner can find it's way into the open carb and cause misreadings.
