so it runs good if you pull the starter clutch, hmm.
> The strange thing is, when I give it some throttle it bogs down and
> dies, but if I give it throttle and pull the clutch lever it sounds
> great.
> Totally lost, and no idea what to try next. Any help would be much
> appreciated.
that said, check all electrical connections, even the ground on the frame, clean n tight? put your fuel filter back too, ru running the the stock air box?
