Re: av7 rebuild - clutch or air leak? so many threads like this one
Rebel Moby /
From experimentation, I found best timing on AV7 or AV10 with static timing CDI box is 1,2mm BTDC.
Stock peashooter exhause is a HUGE restriction on a 50cc, so 74cc kit it is going to be like riding with a bunch of cinder blocks dragging behind you. Open up the exit pipe to 11mm and get fatter jets for that SHA15. Also check if the intake needs derestricting, some neck down to 13 or 14mm at the transition from round to rectangle.
> evil cloud Wrote:
> i should also not that my timing may be off since i forgot to buy the
> cdi puller tool - so waiting for that. i checked with my micrometer and
> it appears that my timing maybhave slipped since the install from what
> it looks like my timing could be quite a bit advanced - beyond 1.5-2 mm
> btdc.
> could that be causing this huge lack of power? but still seems fine on
> the stand??
  av7 rebuild - clutch or air leak? so many threads like this oneTopic by: evil cloud evil cloud 10/06/20 06:31PM
  Re: av7 rebuild - clutch or air leak? so many threads like this oneRe: evil cloud evil cloud 10/06/20 09:58PM
  Re: av7 rebuild - clutch or air leak? so many threads like this oneRe: Rebel Moby Rebel Moby 10/07/20 01:58PM
  Re: av7 rebuild - clutch or air leak? so many threads like this oneRe: evil cloud evil cloud 10/07/20 03:11PM
  Re: av7 rebuild - clutch or air leak? so many threads like this oneRe: Rebel Moby Rebel Moby 10/09/20 05:36PM
  Re: av7 rebuild - clutch or air leak? so many threads like this oneRe: evil cloud evil cloud 10/09/20 06:03PM
  Re: av7 rebuild - clutch or air leak? so many threads like this oneRe: Rebel Moby Rebel Moby 10/10/20 10:54AM
  Re: av7 rebuild - clutch or air leak? so many threads like this oneRe: evil cloud evil cloud 10/10/20 01:06PM
  Re: av7 rebuild - clutch or air leak? so many threads like this oneRe: Rebel Moby Rebel Moby 10/12/20 01:14PM
  Re: av7 rebuild - clutch or air leak? so many threads like this oneRe: Dirty30 Dillon Dirty30 Dillon 10/07/20 06:36AM
  Re: av7 rebuild - clutch or air leak? so many threads like this oneRe: evil cloud evil cloud 10/07/20 12:33PM
  Re: av7 rebuild - clutch or air leak? so many threads like this oneRe: evil cloud evil cloud 10/12/20 11:39PM
  Re: av7 rebuild - clutch or air leak? so many threads like this oneRe: Rebel Moby Rebel Moby 10/14/20 01:45PM
