Re: av7 rebuild - clutch or air leak? so many threads like this one
Rebel Moby /
JB Weld will stand up until you start up the bike, it can not take the heat of exhause and the expanding metal. Need to braze, weld or mechanical methods to keep a pipe in. You can just get rid of the whole backing plate and long exit pipe and replace it with a fabricated plate with two 1/4IPS lamp nipples as exit pipes. Loud and dirty way to get the exhause out and maintain some containment. You will also need fatter jetting.
Curvy intake will not easily give up 15mm all the way through, where ever it necks down will restrict the volume of air-fuel getting through and mess up the vacuum signal over the main jet. I would suggest a correct shorty 15mm and derestrict it to save headaches.
> evil cloud Wrote:
> thanks reb! ive looked through your tutorials on derestricting. im
> wondering if jb weld will hold up on that exit pipe refitting. i saw
> someone else did it a while back but wondering if it held up.
> going to try to time at 1.2 today or tomorrow hopefully.
> i have the curvy intake. chopped to a bit shorter. its pretty bored out
> looking on the inside and where it necks down but im sure it could be
> cleaned up a bit.
  av7 rebuild - clutch or air leak? so many threads like this oneTopic by: evil cloud evil cloud 10/06/20 06:31PM
  Re: av7 rebuild - clutch or air leak? so many threads like this oneRe: evil cloud evil cloud 10/06/20 09:58PM
  Re: av7 rebuild - clutch or air leak? so many threads like this oneRe: Rebel Moby Rebel Moby 10/07/20 01:58PM
  Re: av7 rebuild - clutch or air leak? so many threads like this oneRe: evil cloud evil cloud 10/07/20 03:11PM
  Re: av7 rebuild - clutch or air leak? so many threads like this oneRe: Rebel Moby Rebel Moby 10/09/20 05:36PM
  Re: av7 rebuild - clutch or air leak? so many threads like this oneRe: evil cloud evil cloud 10/09/20 06:03PM
  Re: av7 rebuild - clutch or air leak? so many threads like this oneRe: Rebel Moby Rebel Moby 10/10/20 10:54AM
  Re: av7 rebuild - clutch or air leak? so many threads like this oneRe: evil cloud evil cloud 10/10/20 01:06PM
  Re: av7 rebuild - clutch or air leak? so many threads like this oneRe: Rebel Moby Rebel Moby 10/12/20 01:14PM
  Re: av7 rebuild - clutch or air leak? so many threads like this oneRe: Dirty30 Dillon Dirty30 Dillon 10/07/20 06:36AM
  Re: av7 rebuild - clutch or air leak? so many threads like this oneRe: evil cloud evil cloud 10/07/20 12:33PM
  Re: av7 rebuild - clutch or air leak? so many threads like this oneRe: evil cloud evil cloud 10/12/20 11:39PM
  Re: av7 rebuild - clutch or air leak? so many threads like this oneRe: Rebel Moby Rebel Moby 10/14/20 01:45PM
