Re: Yoke nut stuck on forks!
cheetahchrome . /
Take off front wheel, spin and push the leg up, this should lock the spring back in. You might have to mess with it a little.
This never works. The the problem continues to repeat itself over and over.
You cant torque the flimsy spring tight enough to over come the stuck bolt threads.
He dremeled off the head and got his own proper answer.
