> Mark alan Wrote:
> The red dye is inside the keyway on the flywheel. That must have been a
> mistake in the factory is why they put dye in the first pin. Maybe
> assembly guy had specs from older engine builds. Because these are
> original parts on my bike. I'm the first person that touched the
> flywheel few days ago.
There was no mistake at the factory, someone fucked up the pin, tried to red loctite it, failed, then drilled a new hole
